Hello Guest it is October 24, 2026, 06:22:54 PM
Author Topic: Creating M-Code to activate Outputs  (Read 24545 times)
« on: August 06, 2019, 02:14:47 PM »
Hi I am putting together a machine that requires a number of outputs,  I have figured out how to turn them on and off using buttons on the screen,  but I cannot turn them on in the program.  I tried learning how to create an M-code in Mach4 Scripting Manual but it is not helpful for someone of my caliber.   If you can help me make one that will work I can copy and make the changes for the additional outputs.    I attached my feeble attempt, but it did not work (See attached)   I noticed that there were M-codes that turned on/off outputs (M200-M228) but that did not seem to work.  Any help would be appreciated.   I am using Mach4 and Pokeys 57E
Jeff
Re: Creating M-Code to activate Outputs
« Reply #1 on: August 06, 2019, 07:59:00 PM »
have a look at this thread.....they are sort of related:
https://www.machsupport.com/forum/index.php?topic=41580.0
So the question is whether you want to be able to turn the outputs on or off using m codes which are embedded
in your Gcode program or whether, like the other guy, use a GUI button to turn them on or off.
Note you could do both but would require macros in the macros folder that will be used by Gcode and a basically
indentical function in the screen load script that can be used by the GUI thread. Another way of 'skinning the same cat' is to
have a module.....but start simply and work up to that.
« Reply #2 on: August 06, 2019, 08:13:14 PM »
Hi Craig,
 Thanks for your response.  That is more complex than what I am looking for all I want to do is create an M-code that will turn on/off outputs.  But I am not understanding how to create them. If I could be given an example of one then I could learn from what they did.
« Reply #3 on: August 06, 2019, 09:00:56 PM »
Then you need to answer the question....do you want to be able to turn off from a button OR do you want to turn them on or
off as part of a Gcode job?
« Last Edit: August 06, 2019, 09:15:13 PM by joeaverage »
« Reply #4 on: August 06, 2019, 09:44:29 PM »
As part of the Goode
« Reply #5 on: August 06, 2019, 10:50:25 PM »
OK thats easy.
Open the script editor and enter:
Code: [Select]
function m101()
local inst=mc.mcGetInstance()
local hsig=mc.mcSignalGetHandle(inst, mc.OSIG_OUTPUT1)
local current=mc.mcSignalGetState(inst,hsig)
if current ==1 then
      mc.mcSignalSetSate(inst,hsig,0)
else
      mc.mcSignalSetState(inst,hsig,1)
end
end
if (mc.mcInEditor()==1)then
     m101()
end
Save in the macros folder of your profile as m101.mcs
If in your Gcode file you code m101 then output#1 will turn on, code it a second time and it will turn off.
You will have to use your PoKeys plugin to assign a pin to the output.
Note I am at work and cannot run this through the debugger...may do so when I get home.
« Reply #6 on: August 06, 2019, 11:02:03 PM »
Hi Craig, thank you very much.  It looks Greek to me.  So if I copy that and just change OSIG_OUTPUT1 to OSIG_OUTPUT2 and the m101's to m102's I can control 2 outputs and so on?
« Reply #7 on: August 06, 2019, 11:32:49 PM »
Yes, up to output#63
« Reply #8 on: August 07, 2019, 12:38:40 AM »
Think you could do them all with a single macro and just set the output number using a p var. Something like M201P1, M201P2, etc. Will have to look. I know I did it before.
« Reply #9 on: August 07, 2019, 04:10:44 AM »
whoops, made a mistake, the mc.mcSignalSetState and mc.mcSignalGetState don't need instance parameters:
Code: [Select]
function m101()
local current=mc.mcSignalGetState(hsig)
if current ==1 then
      mc.mcSignalSetSate(hsig,0)
else
      mc.mcSignalSetState(hsig,1)
end
end
     m101()
end
