Hello
Guest
it is
October 24, 2026, 07:32:30 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Creating M-Code to activate Outputs
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Creating M-Code to activate Outputs (Read 24554 times)
Bill_O
615
Re: Creating M-Code to activate Outputs
Reply #10 on:
August 07, 2019, 07:18:46 AM »
this might help
https://www.machsupport.com/forum/index.php?topic=39763.msg266718#msg266718
bill
Logged
JeffMach3
15
Reply #11 on:
August 07, 2019, 10:50:27 PM »
I tried running it and the M code did not do anything. I opened it up in the editor and hit (start debugging) and it said C:\Machhobby\ZeroBraneStudio\bin\lua53. exe: error loading module 'machip' from file 'C:\Mach4hobby\Modules/machip. dll' : the specified module could not be found.
Logged
joeaverage
7,663
Reply #12 on:
August 07, 2019, 11:06:37 PM »
well that a mystery to me, I ran this macro last night through the debugger and MDI and it worked in both instances.
Sounds like some part of the Mach installation is missing.
Logged
JeffMach3
15
Reply #13 on:
August 07, 2019, 11:08:50 PM »
Oh fun, do I try re install it
Logged
joeaverage
7,663
Reply #14 on:
August 07, 2019, 11:11:52 PM »
h'mmmm....I might wait until smurph, Chaoticone or Daz read this post....I'd guess they know abit more about it.
What build Mach are you using?
Logged
JeffMach3
15
Reply #15 on:
August 07, 2019, 11:13:36 PM »
Version 4.2.0.4162
Build 4162
Logged
joeaverage
7,663
Reply #16 on:
August 09, 2019, 04:01:19 PM »
that's the same build as I'm using.
Have a look in Mach4Hobby/Modules for the file machip.dll Is it there?
Logged
joeaverage
7,663
Reply #17 on:
August 09, 2019, 04:05:53 PM »
I notice the file is machip
c
.dll not machip.dll........just the sort of typo that can catch you out.
Logged
JeffMach3
15
Reply #18 on:
August 10, 2019, 01:29:07 AM »
I checked and the file is there.
Logged
Cbyrdtopper
985
Reply #19 on:
August 10, 2019, 12:51:17 PM »
If all you want to do is to turn on and off an output from G Code, you should try using M64 and M65
Look on page 60 of the Mach4 G Code programming manual for mill and router style machines.
M64 P2 this will turn on output 2
M65 P2 this will turn off output 2
Logged
Chad Byrd
Print
Pages:
1
2
3
Go Up
« previous
next »
