Hello Guest it is November 23, 2026, 03:04:05 AM
Author Topic: Creating M-Code to activate Outputs  (Read 25490 times)
Re: Creating M-Code to activate Outputs
« Reply #20 on: August 10, 2019, 02:59:21 PM »
Awesome... It works Thank you
« Reply #21 on: August 10, 2019, 03:17:38 PM »
If all you want to do is to turn on and off an output from G Code, you should try using M64 and M65
Look on page 60 of the Mach4 G Code programming manual for mill and router style machines.
M64 P2   this will turn on output 2
M65 P2   this will turn off output 2
Yup, that is what I was talking about earlier. Forgot they ended up being rolled into Mcodes though.
