Hello Guest it is November 24, 2026, 06:10:30 PM
Author Topic: Soft HOLD in Mach4 Lathe.  (Read 6088 times)
« on: August 03, 2019, 05:01:43 AM »
Hello.
would it be possible to change HOLD key behavior in Mach4 ??
I ask this because a soft STOP would be necessary.
the reason for this request is that I lose the synchronism of the axes causing me error in the plugin.
I'm using the LATHE version.
CSMIO IP S. hardware
thank you.
Re: Soft HOLD in Mach4 Lathe.
« Reply #1 on: August 03, 2019, 05:22:32 AM »
<feed hold> followed by <stop>.
See this thread:
https://www.machsupport.com/forum/index.php?topic=41547.0
« Reply #2 on: August 03, 2019, 07:42:06 AM »
ok.
I read the discussion.
I put the check mark on the stop when I press pause.
it can suffice me, it does not generate more errors.
thank you!
