Hello Guest it is October 30, 2026, 09:48:16 AM
Author Topic: New Simple Lathe Screen Set  (Read 98988 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« on: July 11, 2019, 01:10:21 PM »
Here you are have a play with this new Mach3 only Lathe Screen set.
Its got big buttons so will work with touchscreens and is colourful, this is because it was originally for education use but I was asked to make a general version because people liked it.
The only things that will change are if bugs are found in it.  Nothing will be added or changed that is up to you to do.
Its not like the standard lathe set, if you click the same green option button some of the screens cycle around different options, Position, Offset and Automatic all do this and the last screen is remembered.
That's it, see what you think.
Update:-
I have added the portrait version now so you can turn your monitor on its side.
« Last Edit: November 30, 2019, 05:05:28 PM by Graham Waterworth »
Offline SimonRafferty
  •  46 46
  • Movie SFX Design Engineer
Re: New Simple Lathe Screen Set
« Reply #1 on: December 18, 2020, 01:17:00 PM »
Have you by any chance built a Mach4 Version of this?
Si
  •  2,785 2,785
« Reply #2 on: December 20, 2020, 04:07:50 PM »
