Hello Guest it is November 10, 2026, 11:43:42 AM
Author Topic: Mach4, Home backoff limits  (Read 26707 times)
Offline Boots
  •  17 17
« on: June 30, 2019, 07:20:56 PM »
When “Reference  all home” the machine moves to Z Home switch, triggers it then does not back off. How can we change the Homing routine to move off the homing switch?? In MAch4 I tried increasing the offset but it does not work.
Offline Mauri
  •  328 328
Re: Mach4, Home backoff limits
« Reply #1 on: June 30, 2019, 09:01:37 PM »
Boots,
Below are my settings as an example.
Mauri.
Offline Boots
  •  17 17
« Reply #2 on: June 30, 2019, 11:46:45 PM »
Hi Mauri,
Thanks for the reply - my setup is close to your setup; the only difference is the negative value in the soft limits. I will try that.
Thanks, Boots-2b1
