Hello Guest it is November 13, 2026, 12:44:53 PM
Author Topic: post processor  (Read 14835 times)
post processor
« on: May 13, 2019, 12:57:15 AM »
Where can I post a Postprocessor for Fusion 360 Laser Cutting?
Somewhere I saw a place For posting postprocessors But I cannot find it now.
Chuck
  •  9,377 9,377
Re: post processor
« Reply #1 on: May 13, 2019, 01:12:11 AM »
Most of the Post Processors were tucked in here; https://www.machsupport.com/forum/index.php?board=8.0
Offline reuelt
  •  520 520
Re: post processor
« Reply #2 on: May 13, 2019, 01:52:07 AM »
Chuck
There is a link to Mach3 Postprocessor for Fusion 360 Laser Cutting at Autodesk already.
https://cam.autodesk.com/hsmposts
waterjet/Laser/plasma use the same post processor in Autodesk Fusion 360
« Last Edit: May 13, 2019, 01:57:05 AM by reuelt »
"the gift of God is eternal life through Jesus Christ our Lord"
Re: post processor
« Reply #3 on: May 13, 2019, 02:10:23 AM »
Thanks Teeakie , I knew I saw it somewhere.
 The post processor was developed by Seth, owner of liberty machine.
He wrote it  at my request and it works great on Mach3 from designs  created on Fusion 360 Laser,  water jet  or plasma cutting.
Chuck
Re: post processor
« Reply #4 on: May 13, 2019, 08:37:40 AM »
Reuelt
I initially tried The MACH3 plasma PP For posting my laser Designs And it did not work. Seth From Liberty machine Wrote  this postprocessor Which Works great for what  I'm doing,
Chuck
Offline reuelt
  •  520 520
Re: post processor
« Reply #5 on: May 15, 2019, 07:45:23 AM »
Reuelt
Chuck
Sorry, if I upset you.
The problem with Autodesk post processors is that it is VERSION DEPENDENT.
I have an older version of Inventor HSM pro, and the newer Post Processors by Autodesk will not work unless I manually edit them.
I hope users would always complain/feedback to Autodesk so that AUTODESK would fix the broken or missing post processors otherwise, whenever they upgrade Fusion 360 or Inventor HSM, we will have to write/rewrite POST PROCESSORS ourselves again and again?
Writing working POST PROCESSORS should be the software vendors' duty. We users have less knowledge about their software than them.
« Last Edit: May 15, 2019, 07:49:19 AM by reuelt »
Re: post processor
« Reply #6 on: May 15, 2019, 09:04:06 AM »
 Thanks, I totally understand.
