Mach Discussion => General Mach Discussion => Topic started by: chuck767 on May 13, 2019, 01:57:15 AM
Where can I post a Postprocessor for Fusion 360 Laser Cutting?
Somewhere I saw a place For posting postprocessors But I cannot find it now.
Chuck
Most of the Post Processors were tucked in here; https://www.machsupport.com/forum/index.php?board=8.0
Chuck
There is a link to Mach3 Postprocessor for Fusion 360 Laser Cutting at Autodesk already.
https://cam.autodesk.com/hsmposts
waterjet/Laser/plasma use the same post processor in Autodesk Fusion 360
Thanks Teeakie , I knew I saw it somewhere.
The post processor was developed by Seth, owner of liberty machine.
He wrote it at my request and it works great on Mach3 from designs created on Fusion 360 Laser, water jet or plasma cutting.
Chuck
Reuelt
I initially tried The MACH3 plasma PP For posting my laser Designs And it did not work. Seth From Liberty machine Wrote this postprocessor Which Works great for what I'm doing,
Chuck
Reuelt
Chuck
Sorry, if I upset you.
The problem with Autodesk post processors is that it is VERSION DEPENDENT.
I have an older version of Inventor HSM pro, and the newer Post Processors by Autodesk will not work unless I manually edit them.
I hope users would always complain/feedback to Autodesk so that AUTODESK would fix the broken or missing post processors otherwise, whenever they upgrade Fusion 360 or Inventor HSM, we will have to write/rewrite POST PROCESSORS ourselves again and again?
Writing working POST PROCESSORS should be the software vendors' duty. We users have less knowledge about their software than them.
Thanks, I totally understand.
