Hello Guest it is November 13, 2026, 10:15:19 AM
Author Topic: change spindle speed (eg. laser power) depending on velocity  (Read 9836 times)
« on: August 31, 2007, 06:08:17 AM »
I know that its possible to make the "spindle speed" constroll the power of a laser for an laser engraver, but is there any way to make the software compensate for change in velocity when cutting for example corners.
Re: change spindle speed (eg. laser power) depending on velocity
« Reply #1 on: September 10, 2007, 11:35:55 AM »
That should be under ports and pins Spindle settings... that is what the Lazer option for the spindle should do ...
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
