Hello Guest it is November 13, 2026, 10:01:00 AM
Author Topic: Simple drive controller circuit  (Read 14597 times)
« on: August 30, 2007, 11:02:38 AM »
Hi, everyone. Does anybody know where to get a simple motor drive controller circuit, that works with Mach3 that I can build, to run a little 3 axis router through a PC, 4 step motors, 1.1 amp., 4.1 volts., microstep ?
        Thanks   Jovimon
« Last Edit: August 30, 2007, 11:30:32 AM by jovimon »
Offline Whacko
  •  239 239
  • Happy Days
Re: Simple drive controller circuit
« Reply #1 on: August 30, 2007, 12:23:26 PM »
Nothing's impossible
« Reply #2 on: August 30, 2007, 01:59:55 PM »
http://www.st.com/stonline/products/literature/ds/1334.pdf
Whacko for real
Hey Whacko, many thanks for your idea, I´ll be studying how to get it through, since I´m not very good designing circuits.
     Your giraffe looks great but !! kind of shy !!
« Last Edit: August 30, 2007, 02:06:47 PM by jovimon »
Offline Whacko
  •  239 239
  • Happy Days
« Reply #3 on: August 30, 2007, 03:14:45 PM »
There is a working example in the .pdf document using the L298. It's a reasonably common IC and inexpensive and good for 2A 80V. I used it on a scale model for RND extensively and has good switching characteristics. If you need more help, let me know!
Yep, the giraffe is kinda shy!  :D
Whacko
« Reply #4 on: August 30, 2007, 05:46:08 PM »
Whacko
OK Wacko, I´m going to re-check it.
Offline zarzul
  •  233 233
  • Wyoming, USA
« Reply #5 on: August 31, 2007, 09:55:40 AM »
Good recommendation,
another combination of that is the l297 & l6203 chip.  Do a search on google for those two and you should come up with some circuits.
here is a good one, http://www.majosoft.com/engraving/html/stepper_driver_board_with_l297_and_L6203.html ,
I have built one and I used the application notes from  ST to create the circuit.  Go to their web site and look at their app notes section for these
two chips.
Arnie
« Reply #6 on: August 31, 2007, 11:08:33 AM »
two chips.
Arnie
Thankyou Arnie, I´ll take a look. ;)
     Jovimon
