Hello Guest it is November 11, 2026, 10:39:04 PM
Author Topic: Axis not responding  (Read 12555 times)
Axis not responding
« on: August 22, 2007, 08:09:52 AM »
I am having a real weird problem.
I switched from parallel port to grex and can not get my A axis to respond to gcode
My other axis are responding as should
I can the A axis to jog with no problem but when I run gcode it just passes right over it like it is not even there.
The same gcode worked just fine when I used the parallel port.
BTW, this is the latest version of everything, HELP
Curtis
Re: Axis not responding
« Reply #1 on: August 22, 2007, 09:31:06 AM »
Can you post your XML?
