Third party software and hardware support forums. => Mach3 and G-Rex => Topic started by: curtisturner on August 22, 2007, 09:09:52 AM
I am having a real weird problem.
I switched from parallel port to grex and can not get my A axis to respond to gcode
My other axis are responding as should
I can the A axis to jog with no problem but when I run gcode it just passes right over it like it is not even there.
The same gcode worked just fine when I used the parallel port.
BTW, this is the latest version of everything, HELP
Curtis
Can you post your XML?
