Hello Guest it is November 13, 2026, 01:17:20 PM
Author Topic: Mill or Turn?  (Read 259910 times)
Re: Mill or Turn?
« Reply #60 on: May 05, 2019, 06:43:28 PM »
The lathe post processor  I used in Fusion has the following info when opened:
Copyright (C) 2012-2016 by Autodesk, Inc.
  All rights reserved.
  Mach3 Lathe post processor configuration.
  $Revision: 41301 18455ff67c8df5aa948736e62844bc67de5c8913 $
  $Date: 2017-01-27 13:44:58 $
  FORKID {506EED9A-A4C0-40D3-BC83-CEC4CE91AAEA}
description = "Generic Mach3 Turning";
vendor = "Artsoft";
vendorUrl = "http://www.machsupport.com";
legal = "Copyright (C) 2012-2016 by Autodesk, Inc.";
certificationLevel = 2;
minimumRevision = 24000;
longDescription = "Generic turning post for Mach3.";
The following is the directory of where Mach3 Turning CPS files are  located on my computer:
C:\Users\user\AppData\Local\Autodesk\webdeploy\production\890691bd91ea0296c1b94572fdc7dda4ba2e48f0\Applications\CAM360\Data\Posts
Note that I did modify the CPS file to remove unwanted code that it generated and frankly you really need to know how to do and  what to look for.
There is an "hour long video" on how to modify a post processor, but guessing only that video was on You Tube....so could be wrong.
Sorry, but, it's been over a year since I used Fusion.
« Last Edit: May 05, 2019, 06:45:40 PM by RICH »
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #61 on: May 06, 2019, 01:25:46 AM »
Thanks, slightly different, this is the current one..
  Copyright (C) 2012-2018 by Autodesk, Inc.
  $Revision: 42207 5fa31bcb4a6a27a706165056de7dcda5f53f36d9 $
  $Date: 2018-12-05 15:57:57 $
I will seek the video and have a look. It would have been handy if the Autodesk guy said where the problem was ;)
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #62 on: May 06, 2019, 04:37:38 AM »
Ooh, exciting  :D :D
Managed to successfully edit my post, it now outputs what i want, instead of G28 X.. Z.. it checks the post properties for "G53 home" values, if i enter one i then get G53 X.. Z..
Sounds simple but took a few hours to learn what does what and where to stick brackets etc  ::)
The post had the G53 bits but was not used where i wanted it, just for a parts-catcher  :)
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #63 on: May 06, 2019, 08:24:31 AM »
Just got a reply from CS-Labs regarding G32...
N22 G32 Z-29.816 F1.5
N23 G32 X10. Z-30. F1.5
You can't use two G32 commands one after another. You have to divide them with G0 or G1 command.
The limitation is caused by Mach3 construction.
Mach3 wasn't originally adapted to the G32 function executed by an external controller. We made it possible but with the above limitation.
That explains a lot i think, i don't know if adding a G0 in the code will affect things or if its better to stick with no taper at the thread end???
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #64 on: May 08, 2019, 05:07:59 AM »
I'm setting up my servo drive for the 4th axis, I have not fitted the ENC module yet - should i be able to run the motor without the ENC module??
The drive will lock up as expected when enabled but i cannot get any movement at all.
The manual is vague on servo spindles :( and I have no idea of what to set and where - ports & pins, motor tuning, CS plugin etc.
The 'net seems just as vague as well :(
Any chance someone with a CSMIO IP/A controller and a servo spindle could enlighten me as to what settings i need and where please????
If the post comes, i'll be able to fit the ENC module but i thought that was only for sync when threading??
Offline TPS
  •  2,627 2,627
Re: Mill or Turn?
« Reply #65 on: May 08, 2019, 05:16:23 AM »
you can run spindle without ENC module.
you have to set analog Output in CSMIO plugin config.
https://en.cs-lab.eu/wp-content/uploads/2016/06/user_manual_csmioipa_en.pdf
see chapter 10.6
Offline TPS
  •  2,627 2,627
Re: Mill or Turn?
« Reply #66 on: May 08, 2019, 05:22:45 AM »
btw witch servo Controller are you using?
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #67 on: May 08, 2019, 05:25:44 AM »
Yeah done them, i'll go back out and re-check though.
Do you have to enable Spindle DAC as well as spindle axis? The manual shows both which seems a bit odd as i thought the DAC was for 0-10v VFD outputs?
Do ports & pins plus motor tuning have any bearing at all???
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #68 on: May 08, 2019, 05:27:08 AM »
AASD Chinese from AliExpress
Offline TPS
  •  2,627 2,627
Re: Mill or Turn?
« Reply #69 on: May 08, 2019, 05:32:20 AM »
are you running this Controller in step/dir mode or 0-10V analog mode?
