Hello Guest it is November 12, 2026, 12:51:46 PM
Author Topic: Mill or Turn?  (Read 259583 times)
Offline TPS
  •  2,627 2,627
Re: Mill or Turn?
« Reply #80 on: May 08, 2019, 06:52:32 AM »
not Parameter 001 auxilary function 001!
see 3.4.3 in Manual.
but if you turn the Motor by Hand it seams not to be enabled at all.
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #81 on: May 08, 2019, 11:46:52 AM »
When its enabled, the motor is locked as expected, it just does not move when told.
Will check aux function 1
Ta
Offline TPS
  •  2,627 2,627
Re: Mill or Turn?
« Reply #82 on: May 08, 2019, 11:48:09 AM »
check pn0002 and pn0003 as well
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #83 on: May 08, 2019, 11:51:34 AM »
Yeah i'll set those again in the morning, Pn002 was 1 for speed mode, pn003 was 1 for manual enable or 0 for external enable.
Offline TPS
  •  2,627 2,627
Re: Mill or Turn?
« Reply #84 on: May 09, 2019, 07:23:35 AM »
any success?
Re: Mill or Turn?
« Reply #85 on: May 09, 2019, 07:48:11 AM »
Hey Dave , your email is rejecting me . It says I am spamming you (;-)
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #86 on: May 09, 2019, 08:16:42 AM »
WTF :) Thats the last thing i want ;)
I did just get one from you and i replied.
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #87 on: May 09, 2019, 08:22:20 AM »
any success?
Yes, at last, i reset those two parameters again and enabled it and it sprang into life :) - If had rebooted yesterday it would probably have done it then too.
So, moving on.....
Pid Tuning :(
Of course, CS Labs in their infinite wisdom have removed the Auto-Tune from the spindle servo page :(
I have been plugging numbers for an hour now and although it runs its not happy. It will overshoot then slowly crawl back to dead-band stop, or it will run ok at lower speeds (<1500) but at 3000 it will e-pid fault on max following error accumulator being massive (>100000)
I've had it jumping about so violently i had to e-stop :) and had it sit there slowly moving back and forth but never stopping.
Any ideas how to pid tune a spindle so it can run at 3000 and stop when told?
Getting there but no champagne yet :(
Re: Mill or Turn?
« Reply #88 on: May 09, 2019, 09:14:28 AM »
I set the Chirons spindle up as an axis, did an AutoTune then changed it to a spindle and entered the settings, I then tweaked from there.
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #89 on: May 09, 2019, 10:04:36 AM »
Ooh, thats an idea  :)
