Hello Guest it is November 13, 2026, 01:17:08 PM
Author Topic: Mill or Turn?  (Read 259909 times)
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #70 on: May 08, 2019, 05:41:02 AM »
are you running this Controller in step/dir mode or 0-10V analog mode?
I just ordered the same unit as previous and they were all pre-set for 10-0-10 analogue control, i guess it could be set wrong?
If it is then that will be a problem as the manual is hopeless :(
Offline TPS
  •  2,627 2,627
Re: Mill or Turn?
« Reply #71 on: May 08, 2019, 06:02:01 AM »
think you mean this Manual:
https://www.machsupport.com/forum/index.php?action=dlattach;topic=33543.0;attach=44811
it's not hopeless, only hard to read, but the Controller is the chineese Standard servo Controller witch is sold under
maybe 150 different Labels.
back to the Problem.
for a quick test you can set the enable Input a connect a 1.5v battery to the analog Input (pin25/13 ) to have a look that it is
in analog mode.
as far as i know CSMIO can not be Setup to +/-10V spindle control (only for the moving axis), only 0-10V and
use a servo Controller Input for CCW Operation.Mach3 has only the possibilty to Setup one Output for CW and
an other Output for CCW spindle Operation. therefore you have to use two relay's one for CW (only one NO contact
needed) and the CCW relay (two NO contacts needed).
then the CW relay Switches only the SRV-ON
and CCW relay Switches SVR-ON and CCW Input.
for the Moment i see not in the Manual, how to get a CCW Input confiured, but will Keep on studying.
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #72 on: May 08, 2019, 06:12:14 AM »
I have just been poking with a meter and the CSMIO is outputting about +8v at present so its trying to get the drive to spin.
If i click the backwards jog button in plugin config/pid tuning the voltage drops to negative so CW/CCW seems to be 10-0-10 as expected
I checked the 25 pin connector at the drive and the plug is receiving the voltage from the IP/A
The drive is configured for location mode and is pre-programmed for the correct motor according to the values shown in parameters.
I can't do much more - if its not moving with 8v signal it won't move with 1.5v surely?
Hopefully not a dead drive :(
Offline TPS
  •  2,627 2,627
Re: Mill or Turn?
« Reply #73 on: May 08, 2019, 06:20:26 AM »
for the enable (SVR-ON) you have
24V to pin  and
0V switched to pin 6 ?
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #74 on: May 08, 2019, 06:27:03 AM »
Hi
Yes, i used the same wiring connection layout as the other 4 drives.
I just pulled the control plug, manually enabled it via Pn003=1, the motor locked as expected, then applied 1.5v to pins 13 & 25.
Result was no movement at all.
Seems its drive related at least.
Is there any more i can check or is it time email the seller :(
Offline TPS
  •  2,627 2,627
Re: Mill or Turn?
« Reply #75 on: May 08, 2019, 06:27:26 AM »
i think it should bo in Speed mode not in Location mode.
compare Parameter Pn002 with the other drives.
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #76 on: May 08, 2019, 06:28:09 AM »
Will check another drive, back in a minute....
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #77 on: May 08, 2019, 06:34:03 AM »
It was in Location mode pn0002=2 and the other drives are all =1 so changed it to 1 but still dead.
Offline TPS
  •  2,627 2,627
Re: Mill or Turn?
« Reply #78 on: May 08, 2019, 06:45:54 AM »
what is the Controller Display showing after power up?
have you saved the Parameters via Fn001?
Offline Davek0974
  •  2,606 2,606
Re: Mill or Turn?
« Reply #79 on: May 08, 2019, 06:49:12 AM »
Hi
i cant recall what it was showing but if you twist the motor the numbers go up and down :)
Didn't know about para 1, will have to be later as have hospital visit to go on now ;)
