Hello Guest it is November 11, 2026, 12:56:39 PM
Author Topic: Error Opening Video Window  (Read 11636 times)
Offline olf20
  •  325 325
« on: August 14, 2007, 06:56:51 PM »
Hi all,
I was reading a thread in the bargin basment about the video camera. When I tried to open the video window in Mach3 I get the following error;
Art Code 9991
Is this a function that you have to purchase a special licenses for??
Thanks olf20
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
Re: Error Opening Video Window
« Reply #1 on: August 14, 2007, 07:16:07 PM »
Nope, it should work OK, but might not work if you dont have a camera connected.  I dont have my camera connected at this time but I think the drivers will be there so it just says cant connect to camera, I press ok and the window opens, obviously it just shows a blank screen.
Offline olf20
  •  325 325
« Reply #2 on: August 14, 2007, 10:31:33 PM »
My window will not open at home. I will try the shop computer tomarrow.
Thanks for the reply!!
olf20
« Reply #3 on: August 15, 2007, 09:38:57 PM »
it should work.... You need to close the video stream when you exit.. other then that you should be good to go.
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
