Hello Guest it is October 20, 2026, 05:04:23 PM
Author Topic: MDI does not respond  (Read 39299 times)
« on: August 14, 2007, 11:22:15 AM »
 Hi to every one: I’m new with mach3 and I’m following step by step the manual, when writing the G-code and press enter, I don’t get any response (I have tried several times with different codes). Does anybody could tell me what could be happening?
           Regards
Re: MDI does not respond
« Reply #1 on: August 14, 2007, 01:11:17 PM »
Are your motors moving if you Jog via they keyboard?
Can you post a sample of the code you are trying.
« Reply #2 on: August 14, 2007, 05:20:49 PM »
I'm working "dry run"(no motors hook up), I'm just trying Mach3Mill with the following code:
G21
F100
G1 X10 Y0
G2 X10 Y5
X0
Y0
« Reply #3 on: August 14, 2007, 05:27:46 PM »
if you press the jog keys do your axis DROs change?
« Reply #4 on: August 14, 2007, 05:30:08 PM »
Mach isn't in an e-stop mode is it? Is the reset button led flashing?
« Reply #5 on: August 15, 2007, 03:03:05 PM »
No, nothing happen
« Reply #6 on: August 15, 2007, 03:16:04 PM »
I checked the “General logic configuration” at the  “Program end or M30 or Rewind” column, for the “E-stop the system”, and it is not checked out (it is in blank).
I’m sorry; I don’t see any “Reset Button” anywhere.
     Jovimon
I Checked your "precisionchaos" web page, I see you do a great job.
« Last Edit: August 15, 2007, 03:26:00 PM by jovimon »
« Reply #7 on: August 15, 2007, 03:20:09 PM »
Sounds like you dont have the axis enabled in Ports and Pins. Even if you dont have motors connected you need to enable the axis you want to use as simulation.
 Reset button is lower left on most pages, if its flashing then you will have to go into ports and pins, Inputs and change the active low setting for the E Stop
« Reply #8 on: August 15, 2007, 03:34:19 PM »
I see the Reset Buttom just in the manual, but not anywhere in the software at any page. May be I should reload the software?
    Jovimon
« Last Edit: August 15, 2007, 03:37:46 PM by jovimon »
« Reply #9 on: August 15, 2007, 03:39:07 PM »
Can you post a screenshot here so we can look. Sounds like you may be missing some of the bitmaps or the screen set you have is corrupt, you could try installing mach again to see if that clears it up.
