Hello Guest it is November 11, 2026, 12:36:44 PM
Author Topic: MDI does not respond  (Read 40022 times)
Re: MDI does not respond
« Reply #20 on: August 16, 2007, 02:01:04 PM »
OK Jovimon, That helps a lot. A picture is worth a thousand words. THe problem is this, your not seeing all of your screen. Go to general config and check the box Auto Screen Enlarge, Its down at the bottom, center right. You may have to exit mach and re-open for this to take effect. You may need to play with other settings in Screen control, I don't think so though. Give it a go and let us know. If, when you open general cofig. the bottom it it is missing too, grap it at the top and slide it up so you can get to Screen control.
Thank you Brett. ! finally I could get it ! . Thank you for your patience
« Last Edit: August 16, 2007, 02:03:40 PM by jovimon »
« Reply #21 on: August 16, 2007, 03:02:51 PM »
Your welcome  :) Glad you got it.
