Hello Guest it is November 21, 2026, 03:17:24 PM
Author Topic: PWM output in the HIcon 7766  (Read 29517 times)
Offline lgr
  •  48 48
« on: February 05, 2019, 03:22:18 PM »
I'm considering using this board to control a spindle in place of one unused axis' does the Hicon 7766 output a PWM signal? Thanks
Cnc4Pc C41 - PWM Variable Speed Control Board
https://cnc4pc.com/catalogsearch/result/?q=c41
Re: PWM output in the HIcon 7766
« Reply #1 on: February 05, 2019, 04:02:39 PM »
Hello,
The user manual of the C41S describes that it converts a PWM input signal and outputs 0-10VDC.
The HiCON Integra has an onboard 0-10V digital to analog output for controlling a spindle.
Offline lgr
  •  48 48
« Reply #2 on: February 05, 2019, 04:23:50 PM »
I'm controlling a second spindle with this board
Offline lgr
  •  48 48
« Reply #3 on: February 06, 2019, 05:04:20 PM »
I'm still wondering if this is compatible with the Hicon 7766 to operate a second spindle using an unused axis?
« Reply #4 on: February 07, 2019, 09:45:38 AM »
It's possible to implement a PWM output on the board but would require some time and development fees.
One of our customers uses the SPINDLE_FW/REV signals that each drive a separate spindle. The spindles will only move in one direction with that setup though.
If you would like custom software or firmware modifications you can email sales@vitalsystem.com with your request.
Offline lgr
  •  48 48
« Reply #5 on: February 07, 2019, 03:19:03 PM »
Thanks for the information
