Hello Guest it is October 22, 2026, 03:41:00 PM
Author Topic: Probe  (Read 49471 times)
Probe
« on: February 04, 2019, 11:45:01 AM »
Below is a script i made with machscreen v1.7. but it tells me the the command is too long and points to the block(first line).
hope someone can help me. Thanks
'probe on Z axis
Probe = 1.89  'probe height
Depth = -1.5   'z negative travel
Feed = 4
Code "G20 G31 Z" & Depth & " F" & Feed
While IsMoving()
Wend
SetOEMDRO(802,Probe)
While IsMoving()
Wend
Code "G91 G00 Z.2"
While IsMoving()
Wend
Code "G90"
End
Kenneth
Re: Probe
« Reply #1 on: February 04, 2019, 11:50:07 AM »
64 bit
win 10 pro
24g ram
3.4g processor
Kenneth
Re: Probe
« Reply #2 on: February 04, 2019, 12:08:14 PM »
sorry, using Mach 3
Kenneth
  •  9,374 9,374
Re: Probe
« Reply #3 on: February 05, 2019, 12:58:16 AM »
I don't know if it helps but the line;
Should read;
Call SetOEMDRO(802,Probe)
Re: Probe
« Reply #4 on: February 05, 2019, 04:58:54 AM »
Thanks Tweakie.CNC, i tried that and same error. i think there may be something that
tells the code that there's an end of line.since the error includes the first two lines.
i also have a corner probe button without the "Call" inserted and works fine.
i'm at a lost but will keep looking. Thanks for your info !
Kenneth
Offline TPS
  •  2,627 2,627
Re: Probe
« Reply #5 on: February 05, 2019, 10:05:14 AM »
try to copy the code from machsreen Editor to an other Editor like Notepad++, just to see that there is a correct CRLF at the
end of each line.
Re: Probe
« Reply #6 on: February 05, 2019, 10:23:53 AM »
there are no CRLF at the end of any line. does have NUL at end of file.
THANKS TPS
Kenneth
Re: Probe
« Reply #7 on: February 07, 2019, 12:15:20 PM »
Hi Kenneth
When do you get that error message? When entering use data and close, or when you close MachScreen?
Klaus
The brain isn't a soap, it doesn't shrink when used.
Re: Probe
« Reply #8 on: February 07, 2019, 12:18:50 PM »
i get the error message when i use the button in mach3.
its in the error label. where the estop message is.
Thanks Klaus !
Kenneth
Re: Probe
« Reply #9 on: February 07, 2019, 12:29:28 PM »
Hi Kenneth,
did you try to debug your script in Mach3 with the script debugger?
Select your page with the button
Menu Operator -> Edit button script
click the flashing button of interest
Klaus
