Hello Guest it is November 22, 2026, 02:24:36 PM
Author Topic: G43T Mach3  (Read 10879 times)
Offline TPS
  •  2,627 2,627
G43T Mach3
« on: January 31, 2019, 11:13:43 AM »
has anybody a document witch describes, or maybe knows what a
G43T+toolnumber
exactly does in Mach3.
Re: G43T Mach3
« Reply #1 on: January 31, 2019, 02:20:21 PM »
It's G43 H#, Tool Length Offset.
I believe it applies a Z axis offset equal to the tool length in the tool table.
Usually used with an ATC, or with fixed length tool holders.
Offline TPS
  •  2,627 2,627
Re: G43T Mach3
« Reply #2 on: February 01, 2019, 01:44:10 AM »
hello  Gerry,
thank you for the reply.
i am clear about the G43H.
i only ask about the G43T because i found this in a example for ATC and have
no idea what is does, or should do.
TPS
Re: G43T Mach3
« Reply #3 on: February 01, 2019, 05:32:11 AM »
It's not the correct format for G43, so I don't know what it would do.
It should always be G43 H#.
That like asking what would M6 H1 do.
Offline TPS
  •  2,627 2,627
Re: G43T Mach3
« Reply #4 on: February 01, 2019, 06:05:16 AM »
thats what i thought also.
Thank You
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G43T Mach3
« Reply #5 on: February 11, 2019, 10:12:34 AM »
It could be an old lathe command that is now defunct.
