Hello Guest it is October 30, 2026, 08:06:02 AM
Author Topic: pc crashes in windows 10  (Read 26201 times)
« on: January 06, 2019, 02:55:15 PM »
Hello,
I am new in mach3.
my pc crashes when I run Mach3. My OS is windows 10 32 bit. I have also run the special driver. Thank you in advance
Re: pc crashes in windows 10
« Reply #1 on: January 06, 2019, 03:47:27 PM »
The parallel port driver will not work in Windows 10. You either need to use a 32bit version of Windows 7, or buy an external controller like a UC100 or ESS.
« Reply #2 on: January 23, 2019, 01:09:10 PM »
Hello, I took a uC100, but my pc crashes when I start the software without connecting the controller
« Reply #3 on: January 23, 2019, 02:01:50 PM »
Make sure you are using the latest version of Mach3 from the website. It's the only version that will run in Windows 10.
Offline TPS
  •  2,627 2,627
« Reply #4 on: January 24, 2019, 12:59:37 AM »
« Reply #5 on: January 29, 2019, 10:48:15 AM »
Thanks for the interest
