Hello
Guest
it is
November 11, 2026, 11:13:14 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
FAQs
pc crashes in windows 10
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: pc crashes in windows 10 (Read 26484 times)
yiannis_nter
3
on:
January 06, 2019, 02:55:15 PM »
Hello,
I am new in mach3.
my pc crashes when I run Mach3. My OS is windows 10 32 bit. I have also run the special driver. Thank you in advance
Logged
ger21
6,295
Re: pc crashes in windows 10
Reply #1 on:
January 06, 2019, 03:47:27 PM »
The parallel port driver will not work in Windows 10. You either need to use a 32bit version of Windows 7, or buy an external controller like a UC100 or ESS.
Logged
yiannis_nter
3
Reply #2 on:
January 23, 2019, 01:09:10 PM »
Hello, I took a uC100, but my pc crashes when I start the software without connecting the controller
Logged
ger21
6,295
Reply #3 on:
January 23, 2019, 02:01:50 PM »
Make sure you are using the latest version of Mach3 from the website. It's the only version that will run in Windows 10.
Logged
TPS
2,627
Reply #4 on:
January 24, 2019, 12:59:37 AM »
take a look here:
https://www.machsupport.com/forum/index.php?topic=37291.0
Logged
yiannis_nter
3
Reply #5 on:
January 29, 2019, 10:48:15 AM »
Thanks for the interest
Logged
Print
Pages:
1
Go Up
« previous
next »
