Hello
Guest
it is
October 25, 2026, 06:56:53 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
I need help with a Mach3 error
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: I need help with a Mach3 error (Read 7640 times)
Cav Trooper
2
on:
December 21, 2018, 05:08:55 PM »
I am trying to engrave a circle and I get a radius to end of arc differs from radius to startline 677. I have tried redrawing the circle and I'm using Canvas 8 to draw and CamBam to generate the G codes and tool path. Is there a fix in Mach3?
joeaverage
7,663
Re: I need help with a Mach3 error
Reply #1 on:
December 21, 2018, 05:18:41 PM »
it may be that your CAM program is producing incompatible arc Gcodes for your Mach3 installation.
Double check the IJ mode is set to incremental on the Config/General Config page per the attached.
Cav Trooper
2
Reply #2 on:
December 21, 2018, 11:49:37 PM »
Thank you, that was it. It runs great.
Print
Pages:
1
Go Up
« previous
next »
