Hello Guest it is October 25, 2026, 06:00:51 PM
Author Topic: I need help with a Mach3 error  (Read 7639 times)
« on: December 21, 2018, 05:08:55 PM »
I am trying to engrave a circle and I get a radius to end of arc differs from radius to startline 677. I have tried redrawing the circle and I'm using Canvas 8 to draw and CamBam to generate the G codes and tool path. Is there a fix in Mach3?
Re: I need help with a Mach3 error
« Reply #1 on: December 21, 2018, 05:18:41 PM »
it may be that your CAM program is producing incompatible arc Gcodes for your Mach3 installation.
Double check the IJ mode is set to incremental on the Config/General Config page per the attached.
« Reply #2 on: December 21, 2018, 11:49:37 PM »
Thank you, that was it. It runs great.
