Hello Guest it is October 20, 2026, 02:50:41 PM
Author Topic: Exporting tool table  (Read 12960 times)
« on: November 14, 2018, 03:45:50 PM »
Hi can anyone tell if I can export my mach3 turn tool table with offsets as a file to copy into another computer. I tried to search the forum for this but the search function appears not to be working
Offline TPS
  •  2,627 2,627
Re: Exporting tool table
« Reply #1 on: November 15, 2018, 01:34:13 AM »
i am not a 100% sure,
but i think
c:\mach3\macros\your Profile Name\tool3.dat
contains all the tool data.
Offline rcaffin
  •  1,073 1,073
« Reply #2 on: November 15, 2018, 02:53:03 AM »
tool3.dat does (I think) contain the tool data, but it is in some sort of packed binary format (damn windows!) and may not be much use to you.
Roger
« Reply #3 on: November 15, 2018, 06:50:18 AM »
You can manipulate the tool table a number of  ways, ie; reset it, export the info, import a tool table
by using a Macro / Mcode which you create. Have a look in Support / Downloads / Mach Tool Box and you will find how to info.
Offline TPS
  •  2,627 2,627
« Reply #4 on: November 15, 2018, 08:28:56 AM »
i guess he wanted to move the toolinformation from one mach3 to an other mach3 machine.
« Reply #5 on: November 15, 2018, 09:32:07 PM »
TPS,
Well he has info to do whatever he desires.  ;)
« Reply #6 on: November 16, 2018, 05:22:11 AM »
Thanks for the info guys
