Mach Discussion => General Mach Discussion => Topic started by: Sucram on November 14, 2018, 04:45:50 PM
Hi can anyone tell if I can export my mach3 turn tool table with offsets as a file to copy into another computer. I tried to search the forum for this but the search function appears not to be working
i am not a 100% sure,
but i think
c:\mach3\macros\your Profile Name\tool3.dat
contains all the tool data.
tool3.dat does (I think) contain the tool data, but it is in some sort of packed binary format (damn windows!) and may not be much use to you.
Roger
You can manipulate the tool table a number of ways, ie; reset it, export the info, import a tool table
by using a Macro / Mcode which you create. Have a look in Support / Downloads / Mach Tool Box and you will find how to info.
i guess he wanted to move the toolinformation from one mach3 to an other mach3 machine.
TPS,
Well he has info to do whatever he desires. ;)
Thanks for the info guys
