Hello Guest it is November 23, 2026, 04:07:23 PM
Author Topic: Set up 2 probes at same time in Mach 3  (Read 26179 times)
« on: November 07, 2018, 05:26:04 AM »
Hi Guys,
I have been using a Z Probe since buying my machine with no problems. I have since bought a Digitizing Probe to learn how to use it and see if it is going to be a useful tool.
In Mach 3 under Config>Ports and Pins>Inputs , I only see one input that seems to  relate to Probing.
As I am using a different input for my Digitizing Probe, I had to change the setting I had in Mach 3 for my Z Probe. I don't want to disturb that setting each time I want to use the DP. ( I am trialing the 'Probe It' software. )
Am I able to set up and use BOTH probes without having to change settings in Mach 3?
Steve
Regards
Steve
Re: Set up 2 probes at same time in Mach 3
« Reply #1 on: November 07, 2018, 06:13:36 AM »
I've posted a Brain that "links" a second input to the probe input. It's on the forum somewhere. But I think it only works with the parallel port, and not with motion controllers.
I think that's the only way to do it in Mach3.
« Reply #2 on: November 07, 2018, 11:38:35 AM »
you can have up to four active probe circuits in Mach4.
« Reply #3 on: November 07, 2018, 10:12:04 PM »
Thanks Ger21....I'll have a play and see how it goes.
Regards
Steve
« Reply #4 on: November 07, 2018, 10:15:59 PM »
Thanks Craig,
I didn't really want to know that....lol.
Maybe its time to move to Mach 4....
Steve
Regards
Steve
Offline TPS
  •  2,627 2,627
« Reply #5 on: November 08, 2018, 12:53:42 AM »
use a relay to select the probe.
wire the relay to an Output, and you can select the probe within your probe macro.
« Reply #6 on: November 08, 2018, 02:09:01 AM »
Thats not a bad idea...thanks.
Regards
Steve
Offline rcaffin
  •  1,073 1,073
« Reply #7 on: November 15, 2018, 03:11:57 AM »
I use an output pin to a couple of gates to select which probe I want to use (under Mach3). But that is custom.
Roger
« Reply #8 on: November 15, 2018, 03:44:28 AM »
Roger
Thanks Roger.
I've had a bit of a play ..... I can use the same input but one probe requires a HI signal and the other a LO, so as it stands now, I still have to change the configuration in Mach 3 each time I change probes.
Instead of a gate or a relay , I was thinking of using a changeover switch, but I still have the other problem to overcome yet.
Steve
Regards
Steve
Offline TPS
  •  2,627 2,627
« Reply #9 on: November 15, 2018, 08:33:55 AM »
never saw a documentation about how to Change Input Parameters via VBScript,
maybe someone else know about a possibility.
