Hello Guest it is October 21, 2026, 04:05:32 AM
Author Topic: Set up 2 probes at same time in Mach 3  (Read 25415 times)
Offline Stuart
  •  311 311
Re: Set up 2 probes at same time in Mach 3
« Reply #10 on: November 15, 2018, 09:44:30 AM »
Have a look at machstandmill site
In the manual it’s explained as well as a circuit to do what you want
If I remember you use the timer input for the second probe
Offline TPS
  •  2,627 2,627
« Reply #11 on: November 15, 2018, 01:03:26 PM »
I use an output pin to a couple of gates to select which probe I want to use (under Mach3). But that is custom.
Roger
Thanks Roger.
I've had a bit of a play ..... I can use the same input but one probe requires a HI signal and the other a LO, so as it stands now, I still have to change the configuration in Mach 3 each time I change probes.
Instead of a gate or a relay , I was thinking of using a changeover switch, but I still have the other problem to overcome yet.
Steve
ok then you have to put an other locic/relay in front of the selctor Switch or selector relay,
to get the two probes onto the same switching Level (hi or low what ever you want)
Offline rcaffin
  •  1,073 1,073
« Reply #12 on: November 15, 2018, 03:27:08 PM »
There are two different situations here. The first is where you have touch probes with different outputs but only want to use one at a time. The other is where you actually do have two different probes running in parallel - and yes, such situations do exist with value. If I could figure out how to attach an image to this post I would include a circuit diagram for the two cases.
Oh well, in words then. I don't run the touch probe straight into the Mach3 pins. I use a pull-up (or pull-down, as the case may be) resistor, then a couple of 74HC14 buffer gates, with a switch to select polarity. Some RC noise filtering is included with the gates, and then it is all fed through an opto-isolator into the Mach3 pin. The filtering AND the opto serve as very good blocks against noise.
Roger
Offline TPS
  •  2,627 2,627
« Reply #13 on: November 16, 2018, 12:44:14 AM »
if you use the reply button, you should get the Additional Option possibilty, where you can attach files.
Offline rcaffin
  •  1,073 1,073
« Reply #14 on: November 16, 2018, 02:35:47 AM »
Ah yes - my fault.
See attached (I think).
Roger
« Reply #15 on: November 16, 2018, 05:46:00 AM »
I'd just use a Brain like I suggested earlier.
