Hello Guest it is November 11, 2026, 11:25:25 PM
Author Topic: Mesh CAM filetype  (Read 20556 times)
Mesh CAM filetype
« on: November 06, 2018, 10:24:39 PM »
MeshCAM generates files as *.m but Mach 3 doesn't recognize it as g-code?  Where do I go from here?
Re: Mesh CAM filetype
« Reply #1 on: November 06, 2018, 10:51:18 PM »
In MeshCAM, when you click "Save Toolpath", below the filename, under "Save as type", you need to select a Mach3 post processor. It looks like you are using the Anilam post processor, which is the first one in the list.
« Reply #2 on: November 06, 2018, 11:03:28 PM »
Thanks Gerry.  Yeah saving it as a tap file works OK
