Hello
Guest
it is
November 11, 2026, 11:14:03 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
FAQs
Mesh CAM filetype
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mesh CAM filetype (Read 20553 times)
GregF
9
Mesh CAM filetype
on:
November 06, 2018, 10:24:39 PM »
MeshCAM generates files as *.m but Mach 3 doesn't recognize it as g-code? Where do I go from here?
Logged
ger21
6,295
Re: Mesh CAM filetype
Reply #1 on:
November 06, 2018, 10:51:18 PM »
In MeshCAM, when you click "Save Toolpath", below the filename, under "Save as type", you need to select a Mach3 post processor. It looks like you are using the Anilam post processor, which is the first one in the list.
Logged
GregF
9
Reply #2 on:
November 06, 2018, 11:03:28 PM »
Thanks Gerry. Yeah saving it as a tap file works OK
Logged
Print
Pages:
1
Go Up
« previous
next »
