Hello Guest it is November 13, 2026, 10:54:08 AM
Author Topic: tool changer  (Read 118254 times)
Re: tool changer
« Reply #20 on: October 28, 2018, 06:41:54 AM »
Ah ok you mean update
Re: tool changer
« Reply #21 on: October 28, 2018, 06:44:43 AM »
Do you think it will be solved? or is it advisable to change the controller?
  •  9,377 9,377
Re: tool changer
« Reply #22 on: October 28, 2018, 07:00:29 AM »
Unfortunately, this is an issue we are seeing more and more often here on the forum – The cheap Chinese motion controller’s work but they do not fully support all the Mach3 / Mach4 functions so there will always be problems with these products.
Best advice :-  always buy a product which has the manufacturer’s full support and backup – you may pay more initially but you only need to buy once (many members have said this here on the forum “buy cheap, buy twice”).
Offline TPS
  •  2,627 2,627
Re: tool changer
« Reply #23 on: October 28, 2018, 01:01:36 PM »
i realy don't know,but it is the cheapest way to try.
would be the next "way" after trying the update way.
Offline TPS
  •  2,627 2,627
Re: tool changer
« Reply #24 on: October 29, 2018, 01:00:30 AM »
btw. have you checked, that you are using the latest Version of the Controller plugin ?
Re: tool changer
« Reply #25 on: October 29, 2018, 07:03:41 AM »
hello, excuse my ignorance I am new, how do I do it? thank you.
Offline TPS
  •  2,627 2,627
Re: tool changer
« Reply #26 on: October 29, 2018, 07:39:19 AM »
first of all rename your c:\mach3 Folder to Keep all existing data
here:
https://www.nvcnc.net/xhc-cnc-controller.html
you can find the latest plugin (i think) and saome Manuals how to install a fesh mach3 instalation.
Re: tool changer
« Reply #27 on: October 29, 2018, 03:37:05 PM »
hello, Well, it is already updated, but still the same, where can I look more? thank you.
Offline TPS
  •  2,627 2,627
Re: tool changer
« Reply #28 on: October 30, 2018, 01:47:04 AM »
do you have any Chance to contact the supplier of your Controller ?
Offline TPS
  •  2,627 2,627
Re: tool changer
« Reply #29 on: November 01, 2018, 04:34:40 AM »
another try would be to run the Programm for test in Single Step (Single BLK), to see
wether the look ahead creates this Problem.
