Hello Guest it is November 13, 2026, 09:51:54 AM
Author Topic: tool changer  (Read 118242 times)
Re: tool changer
« Reply #30 on: November 01, 2018, 02:46:03 PM »
hello, I do not understand you.
Offline TPS
  •  2,627 2,627
Re: tool changer
« Reply #31 on: November 02, 2018, 02:01:57 AM »
if you enable in main Screen "single BLK" you can run the GCode Line by line.
you have to press Start for every single line
« Last Edit: November 02, 2018, 02:17:40 AM by Tweakie.CNC »
Re: tool changer
« Reply #32 on: November 02, 2018, 02:03:00 PM »
hello, Sorry, I did not understand, I've tried it, it's still the same, when it reaches line 34, it goes back to line 1.
Offline TPS
  •  2,627 2,627
Re: tool changer
« Reply #33 on: November 05, 2018, 12:11:54 AM »
ok then it Looks like it is something Controller specific.
any Chance to contact the supplier ?
Re: tool changer
« Reply #34 on: November 05, 2018, 10:21:01 AM »
hello, I do not know how to locate it, I searched for it and can not find it to contact, thanks
Re: tool changer
« Reply #35 on: November 09, 2018, 05:09:39 AM »
hello, I've been looking and I've seen that the file m6end is empty is normal? thanks
Offline TPS
  •  2,627 2,627
Re: tool changer
« Reply #36 on: November 09, 2018, 06:09:05 AM »
depends on, what you have selected in Config -> General Config
Re: tool changer
« Reply #37 on: November 09, 2018, 06:29:00 AM »
Offline TPS
  •  2,627 2,627
Re: tool changer
« Reply #38 on: November 09, 2018, 06:31:18 AM »
in this case M6End is not needed
Re: tool changer
« Reply #39 on: December 04, 2022, 11:36:47 AM »
made som minor changes on your M6 macro, lets see, maybe it helps
Code: [Select]
'*                   MACRO - CAMBIO DE HERRAMIENTA AUTOMATICO                   *
'*      Version: 1.1                                                            *
'* Fecha inicio: 26/07/2015                                                     *
'* Fecha modif.: 25/08/2015                                                     *
'*     Objetivo: Realizar el cambio de herramienta automatico en Mach3          *
'*      Fichero: M6start.ms1                                                    *
'* Drescripción:        *
'* 1. Se mueve el eje Z a cero                                             *
'* 2. Se mueve el eje Y a posición segura                                  *
'* 3. Espera a que se pare el mandrino                                     *
'* 4. Se mueve el eje X para soltar herramienta                            *
'* 5. Se mueve el eje Z a posición de intercambio                          *
'* 6. Se mueve el eje Y para encastrar herramienta                         *
'* 7. Activar el cambio de herramienta                                     *
'* 8. Espera a que Mandrino suelta la Herramienta                          *
'* 9. Se mueve el eje Z a cero                                             *
'* 10. Se mueve el eje X e Y a coordenadas nueva Herramienta               *
'* 11. Se mueve el eje Z a posicion de intercambio                         *
'* 12. Desactivar el cambio de herramienta                                 *
'* 13. Espera a que Mandrino coja la herramienta                           *
'* 14. Se mueve el eje Y para descastrar herramienta                       *
'* 15. Se mueve el eje Z a cero                                            *
'* 16. Se mueve el eje X, Y a punto de partida                             *
Sub Main()
'Call SetUserDRO (1200,0)
' Inicialización del temporizador para el cambio de herramienta
'SetTimer(1)
'---------- Mensaje de inicio ---------------------------------------------------
Message "<< Iniciado el cambio de herramienta ..." 'Pone este mensaje en la barra de estado
'---------- Declaravión de Variables --------------------------------------------
MaxToolNum = 5 'Numero máximo de herramientas en el cambiador
ToolUp = -10 'Posición de Z segura arriba
ToolDw = -287.54 'Posición de Z para coger o dejar una herramienta
ToolSf = 90 'Posición de Y segura para extraer o insertar herramienta
'---------- Recoger Información de la herramienta actual ------------------------
ToolOld = GetOEMDRO (1200) 'Tomar el valor de la herramienta actual
x = GetToolChangeStart( 0 ) 'Tomar la posición de X actual
y = GetToolChangeStart( 1 ) 'Tomar la posición de Y actual
z = GetToolChangeStart( 2 ) 'Tomar la posición de Z actual
'---------- Recoger Información de la nueva Herramienta -------------------------
ToolNew = GetSelectedTool() 'Tomar el valor de la nueva herramienta
While ToolNew < 1 Or ToolNew > MaxToolNum 'Si el numero de la herramienta es superior
   'El operador deberá introducir un valor desde la pantalla
   ToolNew = Question ("Introduzca un numero de herramienta válido (1..." & MaxToolNum & ")")
Wend
If ToolNew = ToolOld Then 'Si la nueva herramienta es igual a la existente
   Exit Sub 'Salimos de la subrutina
End If
Message "<< Cambio de " & ToolOld & ",por " & ToolNew
'---------- Movimientos hacia el intercambiador ---------------------------------
'DoSpinStop() ' Parar mandrino
Message "<< Moviendo eje Z a cero ...." 'Pone este mensaje en la barra de estado
Code "G00 G53 Z" & ToolUp 'Subir el eje Z a cero
While IsMoving() 'Esperar a que se ejecute el movimiento
Wend
Message "Moviendo eje Y a posicion segura ..." 'Pone este mensaje en la barra de estado
Code "G53 Y10 X10" 'Desplaza eje Y a posición segura.
Wend
' Realiza un Home
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
Code "G53 Y" & ToolSf 'Desplaza eje Y a posición segura.
Wend
'---------- Espera hasta que el mandrino se pare --------------------------------
Message "<< Espera a que el mandrico se pare ..." 'Pone este mensaje en la barra de estado
'While GetOEMDRO(99) <> 0 'Esperar a que el mandrino se pare
'Wend
Message "<< Mandrino parado ..." 'Pone este mensaje en la barra de estado
'---------- Movimientos para soltar herramienta actual --------------------------
Message "<< Posicionando para soltar herramienta ..." 'Pone este mensaje en la barra de estado
Call MovePos(ToolOld,"X") 'Mover primero eje X a la posición herramienta
Wend
Code "G53 Z" & ToolDw 'Mover el eje Z a la altura de cambio
Wend
Call MovePos(ToolOld,"Y") 'Mover eje Y a la posición soltar herramienta
Wend
Message "<< Posicionado completado ..." 'Pone este mensaje en la barra de estado
'---------- Soltar herramienta actual -------------------------------------------
Message "<< Accionando Change Tool ..." 'Pone este mensaje en la barra de estado
Code "G4 P.25" 'Esperar un pequeño tiempo
ActivateSignal(Output6) 'Activar la salida para soltar herramienta
'Esperar a el sistema neumatico del mandrino indique herramienta liberada
'SetTimer(2)
CTime = 0 'Inicializa el Temporizador
While Not(IsActive(input1) And Not IsActive(input2) And IsActive(input3))
'CTime = GetTimer(2)
CTime = CTime + 1
If CTime > 1000000 Then
Ret = MachMsg("No se ha podido SOLTAR la Herramienta.... Por Favor revise el Circuito neumático del mandrino....", _
"Tool Change Warning", 5)
If Ret = 2 Then
'MachMsg("Cambio de Herramienta Cancelado....", "Tool Change", 0)
Message "<< Cambio de Herramienta Cancelado" 'Pone este mensaje en la barra de estado
Exit Sub
Else
'SetTimer(2) 'Inicializa el Temporizador
CTime = 0
End If
End If
Wend
Code "G4 P1.0" 'Esperar un pequeño tiempo
Message "<< Herramienta Soltada ..." 'Pone este mensaje en la barra de estado
'---------- Movimientos para coger nueva herramienta ----------------------------
Message "<< Moviendo eje Z a cero ..." 'Pone este mensaje en la barra de estado
Code "G53 Z" & ToolUp 'Subir el eje Z para alejarse de la herramienta
Wend
Message "<< Posicionado para coger nueva Herramienta ..." 'Pone este mensaje en la barra de estado
Call MovePos(ToolNew,"X") 'Mover primero eje X a la posición herramienta
Call MovePos(ToolNew,"Y") 'Mover eje Y a la posición coger herramienta
Wend
Code "G53 Z" & ToolDw 'Mover el Eje Z para tomar la Herramienta
Wend
'---------- Coger nueva herramienta -------------------------------------------
Message "<< Desactivar Change Tool ..." 'Pone este mensaje en la barra de estado
DeActivateSignal(Output6) 'Desactivar la salida para coger la herramienta
'Esperar a el sistema neumatico del mandrino indique herramienta esta cogida
'SetTimer(2)
Ctime = 0
While Not(Not IsActive(input1) And IsActive(input2) And Not IsActive(input3))
CTime = CTime + 1
Ret = MachMsg("No se ha podido COGER la Herramienta.... Por Favor revise el Circuito neumático del mandrino....", _
If Ret = 2 Then
Exit Sub
Else
CTime = 0
End If
CTime = 0
End If
'Pregunta por si se ha producido un Error al coger la herramienta
If(IsActive(input1) And IsActive(input2) And Not IsActive(input3)) Then
MachMsg("Colector cerrado sin herramienta... Por favor revise el Colector del mandrino....", _
"Tool Change Warning", 0)
End If
Wend
Message "<< Herramienta sujeta ..." 'Pone este mensaje en la barra de estado
'---------- Movimientos a Coordenadas Seguras ---------------------------------
Message "<< Moviendo eje Y a posición segura ..." 'Pone este mensaje en la barra de estado
Wend
Code "G53 Z" & ToolUp 'Subir el Eje Z
Wend
'---------- Asignar Herramienta recogida en el sistema ------------------------
Call SetUserDRO (1200,ToolNew)
SetCurrentTool( ToolNew )
'---------- Auto Tool Zero ----------------------------------------------------
'Code "(Iniciado Auto Tool Zero...)" 'Pone este mensaje en la barra de estado
'Code "G0 X100 Y100" 'Mueve a la posición de Prueba
'Code "G4 P5" 'Este tiempo me da para poder colocar la sonda
'Code "G31Z-10 F100" 'El movimiento de prueba, puede cambiar la velocidad
'While IsMoving() 'Esperar a que se ejecute el movimiento
'Wend
'ZProbePos = GetVar(2002) 'Obtener el punto exacto cuando la sonda sea golpeada
'Code "G0 Z" & ZProbePos 'Volver de nuevo a ese punto,
'While IsMoving () 'Esperar a que se ejecute el movimiento
'Wend
'Call SetDro (2, PlateThickness) 'Ajustar el eje Z a lo que se establece como espesor de la placa
'Code "G4 P0.25" 'Esperar un pequeño tiempo
'Code "G0 Z" & ToolUp 'Subir el Eje Z
'Code "(Moviendo eje Z a cero)" 'Pone este mensaje en la barra de estado
'---------- Regresar al punto de partida --------------------------------------
Message "<< Regresando al punto de partida ..." 'Pone este mensaje en la barra de estado
Code "G00 X" & x & " Y" & y '& " Z" & z  'Mueve la máquina al punto de partida
Wend
Code "G4 P1.00" 'Esperar un pequeño tiempo
Message "<< Cambio de Herramienta realizado" 'Pone este mensaje en la barra de estado
End Sub
Sub MovePos(ByVal ToolNumber As Integer, ByVal EjeMove As String)
'Subrutina donde estan las posiciones de cada herramienta
Select Case ToolNumber
Case Is = 1
XPos = 125
YPos = 11.2
Case Is = 2
XPos = 299
YPos = 11.2
Case Is = 3
XPos = 474
YPos = 11.2
Case Is = 4
XPos = 815
YPos = 11.2
Case Is = 5
XPos = 991
YPos = 11.2
Case Is = 0 ' Posición de herramienta no existente
XPos = 1164
YPos = 11.2
End Select
If EjeMove = "X" Then
Code "G00 G53 X" & XPos
End If
If EjeMove = "Y" Then
Code "G01 G53 Y" & YPos & " F1500"
End If
End Sub
Hello muy friend, do you know do the automatic changer tool?
