Hello Guest it is November 13, 2026, 07:45:44 AM
Author Topic: USB Camera connection  (Read 22118 times)
« on: August 20, 2018, 11:09:54 AM »
Hi - I have a problem getting a USB camera to be recognised by Mach 3.  I am getting the report "unable to load OSG driver"  The camera works perfectly in Planet CNC.
If there is a solution I would be most grateful to know please?
Re: USB Camera connection
« Reply #1 on: August 20, 2018, 03:13:43 PM »
which plugin are you using?
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: August 21, 2018, 12:47:54 AM »
Klaus - Thanks for reply. I have tried both V2 and V3 on a Win 10 PC. I put the cameras on another Mach 3 setup (Win XP ) and got the same report with both cameras. No other programmes on this PC. The report is the same with the Mach 3 camera screen?
« Reply #3 on: August 21, 2018, 05:07:50 AM »
What type of camera are you using. Is it an USB connected camera?
Klaus
« Reply #4 on: August 21, 2018, 05:54:55 AM »
Klaus - Yes both camera`s are USB. Both work normally on this PC and with Planet CNC.
« Reply #5 on: August 21, 2018, 06:57:51 AM »
The message "OSG driver" is definitly not coming from my plugin.
is this message appearing every time you start the plugin?
Did you install a deticated driver for the camera?
Did you try the camera on a different USB port?
The only requirements for connecting to a camera:
The defautl Mach3 plugin "Video Window" must not be started since the last windows start
The camera must be plugged in before the plugin is started
Klaus
« Reply #6 on: August 22, 2018, 02:50:28 AM »
Klaus - Followed your kind advice. But no solutions. On the XP machine I am getting "Video OCX (driver) cannot be connected" report.
« Reply #7 on: August 22, 2018, 05:44:45 AM »
I'm almost certain, the message "Video OCX (driver) cannot be connected" is generated by the Mach supplied video plugin. Try the following steps
install Mach Plugin Camera V3 from https://kd-dietz.com/index_eng.html
restart Windows
make sure your camera is plugged into a USB port
enable plugin in Mach3              Menu Config-> Config plugins       WebCamPluginV3-Version-V3.09
Restart Mach3
Start Plugin                              Menu Plugin Control -> WebCamPluginV3-Version-V3.09 -> Start camera
Klaus
« Reply #8 on: August 22, 2018, 08:49:43 AM »
Klaus - Reloaded your V3.09 onto the XP computer. It responded with the following:-
Camera plugin needs SP3 (OK)
ENVIRONMENT VARIABLE PATH NOT FOUND.(OK)
The ordinal 254 could not be located in the dynamic link library msi.dll.
Rod
« Reply #9 on: August 22, 2018, 09:27:52 AM »
Hi Rod,
did you install SP3 for WinXP?
If you did, did you reinstall the plugin?
how did the reinstall work out?
Klaus
