Hello Guest it is November 13, 2026, 07:39:40 AM
Author Topic: USB Camera connection  (Read 22117 times)
Re: USB Camera connection
« Reply #10 on: August 22, 2018, 11:44:34 AM »
Klaus -  SUCCESS
Computer did not have SP3 loaded, put it in, then changed the USB port and everything worked.
My thanks for your kind assistance.
Rod
« Reply #11 on: August 22, 2018, 01:53:21 PM »
Hi Rod,
that's good news. I'm glad the plugin works for you.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Re: ip cam
« Reply #12 on: September 11, 2019, 07:14:53 PM »
Hi - I have a problem getting a USB camera to be recognised by Mach 3.  I am getting the report "unable to load OSG driver"  The camera works perfectly in Planet CNC.
If there is a solution I would be most grateful to know please?
I have an ip camera wi fi anyone know how to integrate it to mach3? is there a plug-in?
