Hello Guest it is November 26, 2026, 04:18:26 AM
Author Topic: XHC WB04 plugin  (Read 436377 times)
Re: XHC WB04 plugin
« Reply #20 on: March 20, 2019, 03:33:16 PM »
No dependency's of any kind. Although, this could be a windows protection type of issue. right click on the m4pw file and send me a picture of the screen. I remember I had an issue with the Mach4 help file not displaying until I had enabled allowing it to display as an internet file..
Colten Edwards
www.lasernthings.ca
Re: XHC WB04 plugin
« Reply #21 on: March 20, 2019, 03:44:33 PM »
Thanks for your help with this! I have attached the screenshot as requested.
Re: XHC WB04 plugin
« Reply #22 on: March 20, 2019, 04:23:55 PM »
should have specified more.. Right click and click on properties. there might be a checkbox near the bottom of the screen that comes up..
Colten Edwards
www.lasernthings.ca
Re: XHC WB04 plugin
« Reply #23 on: March 20, 2019, 04:25:50 PM »
Here is what your looking for.
Colten Edwards
www.lasernthings.ca
Re: XHC WB04 plugin
« Reply #24 on: March 20, 2019, 04:38:56 PM »
Hmmm... there doesn't seem to be anything wrong with the permissions.
Re: XHC WB04 plugin
« Reply #25 on: March 20, 2019, 05:14:32 PM »
Not sure what to tell you at this point then. working on one machine of three. very strange.
Colten Edwards
www.lasernthings.ca
Re: XHC WB04 plugin
« Reply #26 on: March 20, 2019, 07:37:10 PM »
Thanks, Colten. I really appreciate you trying to help. Just to clarify, I only tried it on two machines: my dedicated CNC laptop, and my CAD laptop. It runs fine on the CAD laptop, but not on the CNC laptop where I need it.
I will let you know when I find a solution.
Thanks again.
Dave.
Re: XHC WB04 plugin
« Reply #27 on: March 27, 2019, 09:59:36 PM »
I've now purchased a newer model of the device which will allow me to develop for it. You should see some progress within a month concerning the WHB04B version of the driver. Too bad XHC would not step up to the plate and supply either a driver, or a device so someone else can make a driver.
Hi Colten
How is going on the driver for the newer WHB04B.
Re: XHC WB04 plugin
« Reply #28 on: July 22, 2019, 01:25:00 AM »
Hi Colten,
thank“s for the great plugin. It works well but there are some bugs. So, is it possible to get the sourcecode?
Maybe I can fix some problems...
Thank you,
Markus
Re: XHC WB04 plugin
« Reply #29 on: July 31, 2019, 08:29:58 AM »
 I have one of the too, the one with the blue/orange buttons (4 axis version).
Good news is in you diagnostic screen I can see it is actually receiving data/pulses from the device just fine ... I just assume it is getting different codes than those expected. Perhaps it would be possible to make those individual codes user configurable. Or even better have some configuration screen that allows you click a function known/supported by the plugin and then it records the code sent when the user presses the matching button on the remote.
This would ensure at least some flexibility moving forward. I ordered the HB04 myself from amazon, and got the whb04b-4 instead. Not complaining mind you (as that one costs way more :) it seems) but it adds a level of tricky to this whole silly mess.
Ordered this:
but got this:
