Hello Guest it is November 26, 2026, 04:08:08 AM
Author Topic: XHC WB04 plugin  (Read 436373 times)
Re: XHC WB04 plugin
« Reply #90 on: January 01, 2022, 11:16:48 AM »
I'm still using the plugin from 4746, copied into my production install. I've yet to find a later plugin that works unfortunately.
Re: XHC WB04 plugin
« Reply #91 on: March 16, 2022, 01:33:58 AM »
Will this work for xhc HB04B?
Re: XHC WB04 plugin
« Reply #92 on: April 09, 2022, 08:39:27 PM »
Can you guys upload the plug site for us to download it please share.... thank you.
Re: XHC WB04 plugin
« Reply #93 on: April 23, 2022, 08:06:39 AM »
Ok guys, starting with build 4688, I have included a plugin that will handle the WHB04B-4 and WHB04B-6 XHC MPGs.  It will eventually support the older WHB04 but I haven't gotten one in yet to test with.
To be clear, it supports the MPGs that look like this:
Steve
i have same and no detect on mach4 why?
Re: XHC WB04 plugin
« Reply #94 on: April 25, 2022, 10:57:43 AM »
https://www.youtube.com/watch?v=3lp7KtA_5uM&t=262s
Showing yall the setup, Watch my video also work for lastest mach4 version 4.2.0.4839
Re: XHC WB04 plugin
« Reply #95 on: April 26, 2022, 06:44:26 AM »
Hey all, I'm using the plugins copied from the development version in to 4612, seems to work great apart from the step/cont jog
- For versions up to 4746 i have repeatable steps but not continuous mode
- For versions after that up to 4839 i have continuous at all speeds but no steps
Just wanted to confirm if that's what others are experiencing at this stage or if there is a solution to this
Re: XHC WB04 plugin
« Reply #96 on: April 26, 2022, 08:36:28 PM »
Watch my YouTube video, and I'm using mach4 version 4.2.0.4839, with whb04b-6 video proof that it working. Also make sure you don't select MPG # 0, because it not work. You have to select MPG #1 and above then your axis's steps travel will work. Go over my video.
« Last Edit: April 26, 2022, 08:50:13 PM by Nleo22 »
Re: XHC WB04 plugin
« Reply #97 on: April 27, 2022, 01:02:47 AM »
OK thanks Nleo22, switching to MPG #1 worked, continuous and lead mode work well along with 0.1 and 0.01mm steps which is pretty workable, 1mm steps do not work which i think has been mentioned previously.
Re: XHC WB04 plugin
« Reply #98 on: April 30, 2022, 09:01:18 AM »
I try rushing to the video haven't show yall steps.
Here I redo my video and its longer =D, here NEW VIDEO JUST UPLOADED. I'M USING INCHES I CAN MOVE 0.001", 0.010", 0.100", 1.00" etcs...
https://www.youtube.com/watch?v=Gl-XXBQ_T8M
make sure select MPG #1 and Macro 10= select function "Machine Enable"
Let me know it working for you. look forward to your answer.
« Last Edit: April 30, 2022, 09:06:45 AM by Nleo22 »
Re: XHC WB04 plugin
« Reply #99 on: May 01, 2022, 05:29:09 PM »
I took a break and upgraded my motion controller card to an ESS. Combined that with the fantastic MB3 break out board from CNC Room. Solved several mysteries with my spindle control. I thought I was in the clear....
I was almost successful getting the plugin from build 4839 to work about two weeks ago, but missed an important step. So I ordered a ShuttlePRO V2 ($150 USD)and had zero luck with that :o Really didn't know what to do next. But the clock was ticking, and my patience was just about done. So I really appreciate the info you have shared. Thank you. I can finally go back to work. Oh yes...and I can return my ShuttlePRO V2 and put the cash into material purchases.
Thanks again for taking the time and effort!
Chris
