Hello Guest it is November 13, 2026, 10:44:59 AM
Author Topic: newbie needing advice  (Read 32152 times)
Re: newbie needing advice
« Reply #20 on: May 04, 2018, 09:58:09 AM »
Yes sir that is correct
Offline TPS
  •  2,627 2,627
« Reply #21 on: May 04, 2018, 10:24:08 AM »
can you please post a screenshot from Config -> System Hotkey's ?
« Reply #22 on: May 04, 2018, 10:29:26 AM »
Yes I can, however it would be later this evening. I am currently away from the shop for today and taking a break from trying to figure this out so I don’t take a torch to this whole setup. LOL
Offline Davek0974
  •  2,606 2,606
« Reply #23 on: May 04, 2018, 12:49:14 PM »
What i would next is flip the dir-active-low setting in ports and pins.
Now try jogging but with the OPPOSITE key you would expect so down arrow to move away from you and note the DRO readings +/-
Report back ;)
« Reply #24 on: May 04, 2018, 01:19:07 PM »
Ok, i will try that this evening Dave. And let you know what happens. Thanks again
Offline TPS
  •  2,627 2,627
« Reply #25 on: May 05, 2018, 01:56:46 AM »
first you have the Problem with the arrow key?
arrow up must give positive DRO, then get the movement according to the DRO.
