Hello
Guest
it is
November 13, 2026, 09:43:37 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
newbie needing advice
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: newbie needing advice (Read 32147 times)
gadawgsfan
14
Re: newbie needing advice
Reply #20 on:
May 04, 2018, 09:58:09 AM »
Yes sir that is correct
Logged
TPS
2,627
Reply #21 on:
May 04, 2018, 10:24:08 AM »
can you please post a screenshot from Config -> System Hotkey's ?
Logged
gadawgsfan
14
Reply #22 on:
May 04, 2018, 10:29:26 AM »
Yes I can, however it would be later this evening. I am currently away from the shop for today and taking a break from trying to figure this out so I don’t take a torch to this whole setup. LOL
Logged
Davek0974
2,606
Reply #23 on:
May 04, 2018, 12:49:14 PM »
What i would next is flip the dir-active-low setting in ports and pins.
Now try jogging but with the OPPOSITE key you would expect so down arrow to move away from you and note the DRO readings +/-
Report back
Logged
gadawgsfan
14
Reply #24 on:
May 04, 2018, 01:19:07 PM »
Ok, i will try that this evening Dave. And let you know what happens. Thanks again
Logged
TPS
2,627
Reply #25 on:
May 05, 2018, 01:56:46 AM »
first you have the Problem with the arrow key?
arrow up must give positive DRO, then get the movement according to the DRO.
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
