Hello Guest it is November 23, 2026, 03:42:39 AM
Author Topic: mach 4 plasma  (Read 42118 times)
Re: mach 4 plasma
« Reply #30 on: August 01, 2019, 11:50:38 PM »
Thank you so much cncNor!!!!!! It worked! Success!!!!
So it touches off just how i wanted without the use of arc ok wires.....
So only torch on and off and touch off! 😁👍
Re: mach 4 plasma
« Reply #31 on: August 02, 2019, 09:37:51 AM »
Yup, that is how I designed it to work. Glad you got it sorted.  :)
Now you should be able to use the up and down buttons in the lower THC panel to jog the Z up and down manually as it is cutting. So, you can adjust your cut height on the fly. You can do the same thing manually that a THC does automatically.
Re: mach 4 plasma
« Reply #32 on: August 02, 2019, 10:21:04 AM »
Thank you so much for your help there's just one thing though does it matter if my Z axis isn't assigned to motor to in the Mach configuration? Because I just have motor 0 and slave is one motor to use my y axis and motor 3 is my Z axis
Re: mach 4 plasma
« Reply #33 on: August 02, 2019, 11:44:39 AM »
Have a look in your C:\Mach4Hobby\Docs folder, Plasma_Configuration.pdf. That is covered on page 2 and 3.
Re: mach 4 plasma
« Reply #34 on: September 06, 2019, 11:50:28 PM »
Quick question my guy...
Does youre set up adjust automatically to any distance change between torch and material when using the rouch off feature?
I was given a few tips to input in my machb4 software but im not getting auto adjustments when touching off when it moves to another area on material thats closer/ further away....
Any help?
