Hello Guest it is November 13, 2026, 04:34:04 PM
Author Topic: Problem with scaling(?)  (Read 9835 times)
« on: February 13, 2018, 06:08:47 PM »
Running Mach3. My machine has an issue. If I say move 26 mm (about one inch) it only moves a very tiny amount. If I make a part, it makes it like it is on the head of a pin. Scale says 1:1 and does not deem to be changeable. Any ideas?
Re: Problem with scaling(?)
« Reply #1 on: February 13, 2018, 07:17:46 PM »
Your steps/unit are probably wrong.
Make sure your Native UNits is set correctly, and then calibrate the axes.
« Reply #2 on: February 14, 2018, 09:15:54 AM »
Native units are set to metric. Verified that command X26 moves the X axis exactly one inch so should be correct.
  •  9,377 9,377
« Reply #3 on: February 14, 2018, 09:46:20 AM »
Try adding G20 to the start of your Gcode file.
« Reply #4 on: February 14, 2018, 03:51:31 PM »
Hi
26mm is 1.0236 inch not one inch
Graham
