Hello
Guest
it is
November 23, 2026, 07:07:01 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Problem with scaling(?)
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Problem with scaling(?) (Read 9874 times)
Rick_Knecht
5
on:
February 13, 2018, 06:08:47 PM »
Running Mach3. My machine has an issue. If I say move 26 mm (about one inch) it only moves a very tiny amount. If I make a part, it makes it like it is on the head of a pin. Scale says 1:1 and does not deem to be changeable. Any ideas?
Logged
ger21
6,295
Re: Problem with scaling(?)
Reply #1 on:
February 13, 2018, 07:17:46 PM »
Your steps/unit are probably wrong.
Make sure your Native UNits is set correctly, and then calibrate the axes.
Logged
Rick_Knecht
5
Reply #2 on:
February 14, 2018, 09:15:54 AM »
Native units are set to metric. Verified that command X26 moves the X axis exactly one inch so should be correct.
Logged
Tweakie.CNC
9,378
Super Kitty
Reply #3 on:
February 14, 2018, 09:46:20 AM »
Try adding G20 to the start of your Gcode file.
Logged
GRAYHIL
202
Reply #4 on:
February 14, 2018, 03:51:31 PM »
Hi
26mm is 1.0236 inch not one inch
Graham
Logged
Print
Pages:
1
Go Up
« previous
next »
