Mach Discussion => General Mach Discussion => Topic started by: Rick_Knecht on February 13, 2018, 07:08:47 PM
Running Mach3. My machine has an issue. If I say move 26 mm (about one inch) it only moves a very tiny amount. If I make a part, it makes it like it is on the head of a pin. Scale says 1:1 and does not deem to be changeable. Any ideas?
Your steps/unit are probably wrong.
Make sure your Native UNits is set correctly, and then calibrate the axes.
Native units are set to metric. Verified that command X26 moves the X axis exactly one inch so should be correct.
Try adding G20 to the start of your Gcode file.
Hi
26mm is 1.0236 inch not one inch
Graham
