Hello Guest it is November 13, 2026, 11:59:11 AM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 293002 times)
Offline TPS
  •  2,627 2,627
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #170 on: February 28, 2018, 11:02:02 AM »
Really interesting, on my second pierce, when it goes to probe it changed my cutting speed From 130 ipm  to 30 ipm.?
ok my fault will give you new code soon
« Reply #171 on: February 28, 2018, 11:07:00 AM »
Thanks for all the help, I really appreciate it.
« Reply #172 on: February 28, 2018, 11:24:42 AM »
I removed  the f30 line out and it fixed it. Now I just need to figure out why the THC is diving on 2nd pierce.
Offline Davek0974
  •  2,606 2,606
« Reply #173 on: February 28, 2018, 11:44:02 AM »
I have never seen this, as far as i know, the only things that can change the speed are :- Code, Feed Override, MDI
If yours is changing outside these commands then you have a problem I think.
« Reply #174 on: February 28, 2018, 11:54:54 AM »
It was the code, I got it fixed it’s good now. The problem I’m running into now is with my THC. The code will run great through the first pierce, but when it picks itself up to go to pierce #2, it only raises up “x” instead of raising up 1”. This throws the Z axis location off in MACH and then drives into material on next cut.
« Reply #175 on: February 28, 2018, 11:58:18 AM »
Could it be because I’m using a PP that is designed to run without a THC?
Offline Davek0974
  •  2,606 2,606
« Reply #176 on: February 28, 2018, 12:36:26 PM »
Doubtful, the port won't know a plasma cutter form a mill - its just a port.
After the cut, there should be an M05 which turns the torch off, then a G00 Znn where nn is your clearance height.
The clearance height is relative to the height by your probing routine, if the probing works, then the torch tip should return to clearance height after every cut.
Any chance you can show some code?
« Reply #177 on: February 28, 2018, 12:48:41 PM »
everything seems ffine to me,..,
« Reply #178 on: February 28, 2018, 12:54:01 PM »
When I run my code without the THC inputs active and with just probing, it (probing) works flawlessly. It’s when I activate my THC inputs in Mach then turn my THC on in the plasma sceeenset.
Offline TPS
  •  2,627 2,627
« Reply #179 on: February 28, 2018, 01:01:54 PM »
ok this code should work, and restore original feedrate
pierceHeight = 0.5 'enter here a value for wanted pierceheiht
   orgspeed=GetDro(18)
   code "F30"
   code "G31 Z-1"
   While Ismoving()
   Wend
   code "G00 Z" & GetVar(2002) 'go back to the  probepoint
   While Ismoving()
   Wend
   code "G91 Z" & pierceHeight
   While Ismoving()
   Wend
   code "G92 Z0"
   While Ismoving()
   Wend
   Code "G90"
   Code "F" & orgspeed
