Hello Guest it is November 13, 2026, 12:55:39 PM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 293075 times)
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #80 on: February 15, 2018, 11:26:31 AM »
is this the correct file?
« Reply #81 on: February 15, 2018, 11:27:58 AM »
this is the only part witch is  urgent for now:
Notes:
 When in THC mode, motion will not begin until THCON (Torch OK) signal becomes active.
This being said, my TORCH ON is lit up anytime the THC is in test mode, the TORCH UP and TORCH DOWN were alternating but the TORCH ON was a solid led on.
Offline TPS
  •  2,627 2,627
« Reply #82 on: February 15, 2018, 11:36:33 AM »
ok your M3 macro is Standard, should be no Problem.
what are your Settings in
Config -> Ports&Pins -> Spindle Setup ->CW Delay Spin Up ?
« Reply #83 on: February 15, 2018, 11:38:24 AM »
This setting I have always adjusted based on material thickness, but I usually leave it on .5 seconds as a standard. My spin down is 1 second and the immediate relay off is checked
« Reply #84 on: February 15, 2018, 11:47:16 AM »
This is such a headache. I feel like I’m so close..  ???
Offline TPS
  •  2,627 2,627
« Reply #85 on: February 15, 2018, 11:55:35 AM »
i have tested this Little GCode:
F50
S0
G1 X0 Y0
M3
G1 X10 Y0
here:
i have two situations tested
1. run Programm without THC ON Signal -> machine waits after M3 until THC ON is high.
2. run Programm with THC ON allready high -> Machine start's M3 immediately (after CW Delay Spin Up time)
so i am a little bit out off ideas now.
BTW Config ->Ports&Pins -> Spindle Setup -> Special Option's are all disabled ?
Offline Davek0974
  •  2,606 2,606
« Reply #86 on: February 15, 2018, 12:03:19 PM »
Torch/code freezes after M03....
That is correct behaviour - the the torch is firing on the M03 signal BUT mach3 is NOT seeing an Arc-Ok signal so it will NOT move at all.
The Proma is either not sending or not seeing the arc-ok.
As a test, go ports&pins and disable Arc-Ok IIRC this should let it move without seeing the signal.
« Last Edit: February 15, 2018, 12:05:44 PM by Davek0974 »
Offline TPS
  •  2,627 2,627
« Reply #87 on: February 15, 2018, 12:06:25 PM »
one more idea:
pls doublecheck that the port and pin you have configured is nowhere else used in Input configuration.
Offline TPS
  •  2,627 2,627
« Reply #88 on: February 15, 2018, 12:07:18 PM »
he did this allready see one or two sides before
« Reply #89 on: February 15, 2018, 12:12:36 PM »
I got arc ok signal, torch is firing and moving. I had to disable my x home z home a home y home, but getting proper signal now. Now the issue is that the THC is diving the torch head into the material when it’s going for its 2nd pierce
