Hello Guest it is November 22, 2026, 07:07:07 AM
Author Topic: accuracy is off  (Read 20521 times)
accuracy is off
« on: January 29, 2018, 08:27:48 AM »
Hi I have a 4x4 woodworking cnc router from cncrouterparts, I am having an issue with accuracy, I have had the machine about 5 years and have never had this problem before. just recently my parts started coming out 1/8" under size
I first checked the soundness of my machine for loose parts etc. that was not it, I rechecked my program to see if I had the right bit loaded that was not it. my test consisted of cutting a 3 inch hole and a three inch plug in 3/4  in MDF
 the plug came out 2 7/8" and the hole 3 1/8"  ??????  HELP
Re: accuracy is off
« Reply #1 on: January 29, 2018, 08:40:03 AM »
Verify that your axis calibration is correct.
Ran fine for 5 years ?
How did you generate the code for the test ?
Looks like a .125" cutter without inside or outside offset selected. Cut ON the contour.
Re: accuracy is off
« Reply #2 on: January 29, 2018, 08:57:05 AM »
I used V carve pro to generate the code, my cutter was 1/4 end mill, there were no offsets selected
yes ran fine for five years, did another test by cutting a 6" square and a 4" hole centered inside the square came out 5 7/8" outside and 4 1/8" inside otherwise its very precise edges are square and the part itself is square
Re: accuracy is off
« Reply #3 on: January 29, 2018, 09:00:14 AM »
can you elaborate on axis calibration?
  •  9,378 9,378
Re: accuracy is off
« Reply #4 on: January 29, 2018, 09:02:35 AM »
Hi Mike ,
If you post the Gcode file we can verify that it should cut the part correctly.
Re: accuracy is off
« Reply #5 on: January 29, 2018, 09:04:44 AM »
I have never done that before
can you tell me how please?
Re: accuracy is off
« Reply #6 on: January 29, 2018, 12:18:21 PM »
Post that last test code along with the actual diameter of the tool you used.
Just copy and paste the generated code in your next post.
Quick calibration. Command a move of several inches, measure the actual distance ... compare.
Re: accuracy is off
« Reply #7 on: January 29, 2018, 01:05:59 PM »
overloaded I have it on my desktop but cant seem to get it over here
I tried the code button and the email button
nothing works
Re: accuracy is off
« Reply #8 on: January 29, 2018, 01:12:32 PM »
Use the Reply button, not the quick reply.
Below your message is Additional Options , Attach:  Browse to your .tap or .txt file and attach it.
Re: accuracy is off
« Reply #9 on: January 29, 2018, 01:40:54 PM »
for some reason I cant get it to attach, I have the file right next to the box that says choose file but nothing I do will let me attach it
it ie a txt file so it should attach?
