Hello Guest it is September 14, 2026, 07:28:15 PM
Author Topic: AlphaCAM, Mach3 milling post processors  (Read 121192 times)
Offline viz
  •  17 17
Re: AlphaCAM, Mach3 milling post processors
« Reply #10 on: January 07, 2013, 06:42:27 AM »
Hello, how about new Alphacam 2013 post processor for Mach3 ?  Anybody tried ?
« Reply #11 on: May 20, 2013, 12:27:17 AM »
Hi Graham my name is Henry. I've read your post and downloaded the post for alphacamm, the problem I'm having is that the code stops running when it gets to a radius, of any size, then I have to reset and run for it to continue only for it to stop on the next bit of code with a radius(or beginning of diameter). Is there a way around this problem. I would appreciate help with this issue as I am about to purchase a complete retrofit kit but I need to know whether this could be resolved. cheers
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #12 on: May 20, 2013, 07:23:37 AM »
Hi Henry,
post the code you are trying to run and attach the AlphaCAM file so I can see where your problem originates.
Graham
« Reply #13 on: May 20, 2013, 04:33:54 PM »
Hi Graham, Ive sent the code for a square pocket with radii in the corners. Thanks for the quick response.
« Reply #14 on: May 20, 2013, 05:31:01 PM »
Hi Graham, Henry again. My apologies, I did not mention that this was a demo version that I was using and maybe that is why its not working
  •  2,785 2,785
« Reply #15 on: May 20, 2013, 05:40:34 PM »
Please post the Alphacam file you used to produce the code
« Reply #16 on: May 20, 2013, 06:37:27 PM »
Hi Graham here is the code from Alpacam
« Reply #17 on: May 20, 2013, 06:44:39 PM »
Hi Graham, this is code from Alpha edit
« Reply #18 on: May 25, 2013, 12:40:47 AM »
Hello dear friends,
I am just new here. your forum is very good and useful.
I have a problem with Mach 3 & AlphaCAM 2013. I hope you could help me. I have downloaded your Mach 3 post processor but unfortunately my Milling Machine does not support it. I have a 2.5 axis CNC milling and I use ArtCAM for my modeling and G-Coding. In ArtCAM I  use Mach 2 mm.cnc post processor. But I can find anything like this for AlphaCAM. Can you help me?
« Reply #19 on: May 25, 2013, 08:44:17 AM »
Hello,
Your machine or software supplier is actually the one to ask help for your specific Post Processor to be compatible with Mach 3.
