Hello Guest it is November 13, 2026, 10:33:58 AM
Author Topic: new setup issues  (Read 59990 times)
new setup issues
« on: November 02, 2017, 06:23:31 PM »
ok i did this once 6 yrs ago and cant remember what i need to do to get a machine working with mach
chinese 3040 machine
mach installed, a good version i had last time that i know isnt buggy
where do i start?
thanks a ton in advance for any help
Re: new setup issues
« Reply #1 on: November 03, 2017, 12:47:01 AM »
« Reply #2 on: November 03, 2017, 10:12:55 PM »
Ok thanks for that
Running the driver test finally allowed me to clear the emergency Mach had when first opened
But I cannot jog yet at all
Any idea where to start with that?
« Reply #3 on: November 03, 2017, 10:39:21 PM »
just to be sure, when you hit the Estop button Mach is disabled? With the Estop button released you can <Reset> and Mach Enables? This proves that
you have basic communication between the parallel port and Mach.
On Config/Ports and Pins make sure Port1 is enabled and on the Motor Outputs page enter on the X axis Enabled, pin 2, pin3, port1,port1 per the screenshot attached.
Hook your driver to the Step/DIR pins.
On the MDI page hit <tab> and the jog flyout will appear and you should be able to jog the X axis. If The Jog Control LED is light then the arrow button should work
too.
« Reply #4 on: November 03, 2017, 10:42:14 PM »
think, and I should have mentioned, that you'll need to restart Mach, in fact you may have to restart your PC for the Parallel Port Driver to read the new axis
assignment.
« Reply #5 on: November 03, 2017, 11:24:04 PM »
Now the emergency stop alarm won't clear again lol
« Reply #6 on: November 03, 2017, 11:28:35 PM »
« Last Edit: November 03, 2017, 11:30:34 PM by woodworker84 »
« Reply #7 on: November 03, 2017, 11:35:47 PM »
go back to the beginning have you got a working Estop button? That is a physical switch which causes Mach to disable?
« Reply #8 on: November 03, 2017, 11:36:48 PM »
Yes and yes it's released
« Reply #9 on: November 03, 2017, 11:40:17 PM »
kool, with it released can you reset Mach?
