Hello Guest it is November 13, 2026, 09:45:22 AM
Author Topic: new setup issues  (Read 59976 times)
Re: new setup issues
« Reply #10 on: November 03, 2017, 11:42:38 PM »
Reset Mach but the alarm remains
« Reply #11 on: November 03, 2017, 11:46:15 PM »
Ok I just uninstalled it
And re installed it
Run the driver test
And can clear the emergency alarm now again in Mach
« Reply #12 on: November 03, 2017, 11:48:52 PM »
please explain by what you mean 'alarm remains'. If an Estop is signalled by your Estop switch you CANNOT reset Mach. The Estop condition
must be removed before you can reset. I'm wondering if you are seeing the original warning and despite being reset the warning remains on screen
despite the fact the emergency condition is now cleared?
« Reply #13 on: November 03, 2017, 11:49:23 PM »
No alarm now
« Reply #14 on: November 03, 2017, 11:50:06 PM »
Diagnostic page shows nothing in pulse frequency
Nothing in time in int
« Reply #15 on: November 03, 2017, 11:55:53 PM »
kool, the Estop is really about the only input that must work perfectly. In addition to being a safety requirement it demonstrates communication from the
BoB and parallel port back to Mach.
Just to satisfy yourself please Etsop and then reset Mach several times.
I see from your previous screenshot that you have the X axis hooked to pins 2 and 6 port 1. Is This correct? Are the wires from the X axis driver in the terminals
2 and 6? Are the driver inputs opto coupled? Is there a common, either 0V or 5V on each Step and Dir ports?
« Reply #16 on: November 03, 2017, 11:57:51 PM »
oops...that's not so good. Can you run the DriverTest.exe again and get a screen shot? If the parallel port is not running you might as well give up and go to the pub!
« Reply #17 on: November 04, 2017, 12:00:21 AM »
I don't know know anything about what your saying there
Mine is just a plug x into x z into z set-up lol
« Reply #18 on: November 04, 2017, 12:02:56 AM »
Driver test
Before I reinstalled it, I was screwing around with the kernels and got the reading in the pulse frequency, but not now
« Reply #19 on: November 04, 2017, 12:03:49 AM »
try the DriverTest.exe first and then it might be time to take the top off the controller box and have a look, I know it smells of chop suey, I can smell it
from here!
