Hello Guest it is November 03, 2026, 02:51:25 AM
Author Topic: 3040T and Z Touchplate  (Read 51815 times)
« on: October 17, 2017, 06:10:29 AM »
Hi...I am trying to get info on how to connect a Z Touch Plate on a Chinese 3040T...I can not get any help from Where I Purchased it, Asked for a schematic etc...nothing.... Does anyone know how to hook up a Z Touch Plate with one of these... The 3040T ..Has the Single Cable Output from the Controller to the Engraver...
TIA
Billy
Re: 3040T and Z Touchplate
« Reply #1 on: October 17, 2017, 06:49:45 AM »
do you have a spare input on your controller?
  •  9,375 9,375
« Reply #2 on: October 17, 2017, 06:50:13 AM »
« Last Edit: October 17, 2017, 06:55:07 AM by Tweakie.CNC »
« Reply #3 on: October 17, 2017, 06:58:10 AM »
Thanks but I am Looking for the Actual...Red Wire goes here, Black Wire Goes There...
« Reply #4 on: October 17, 2017, 06:59:56 AM »
It has to intercept a signal to the stepper motor...correct?....
« Reply #5 on: October 17, 2017, 08:19:16 AM »
Would I come off the Power Supply...or off the Z Board...I have to assign it a PIN and a Low Out put...Just not 100% Sure and I would hate to blow anything up
  •  9,375 9,375
« Reply #6 on: October 17, 2017, 10:00:51 AM »
NO
You take a wire from whichever Port and Pin is assigned as 'Probe' in Config. / Ports and Pins. This wire is connected to your 'touch plate'. If your cutting tool is not already connected to GND then you may need an additional wire. You then add a suitable script to the on-screen Auto Tool Zero button.
« Reply #7 on: October 17, 2017, 10:05:51 AM »
Thank you ! !  Every thing I looked at was saying something a bit different . ! ! !
« Reply #8 on: October 17, 2017, 10:35:43 AM »
so do you have a spare input you can assign as a probe input?
« Reply #9 on: October 17, 2017, 10:38:37 AM »
I have to Double Check ...I believe...pin 5 & 14...I popped open the Control Box last week to take a look
